06 Durrango misfier code!
We had a squirrel problem, he chewed the wire to # 4 cyl and # 6 cyl
Wires were repaired but we there is still a miss, it is showing a # 6 misfire on scanner, but I check # 6 fires fine.
#4 has no fire! I replaced coil and spark plug no change there is power going to coil just no spark any ideas what else to check
You may need to to reset the codes by disconnecting the negative terminal on the battery and follow these steps:
http://www.ehow.com/how_5063757_rese...e-durango.html
FF
FF
