2nd Gen Durango 2004 - 2009
Transmission problem
Old Jan 31, 2010 | 01:51 AM
patbras's Avatar
patbras
Question Transmission problem
Hello All,
I need your help with the following: I own a Durango 05 and recently i noticed the transmission is sounding a bit off. Higher rpms and sometimes a soft clunk sound when gearing down. Now when driving steady there is a wobble ( like you drive over a sideline, although very lightly)
Does anybody have an idea what it can be? could it be transmission torque converter? and if so what should I expect to pay to have that repaired?
Looking forward to your helpful reply
Old Jan 31, 2010 | 04:15 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Try cleaning the throttle body and changing your shocks. There are a few threads about a mysterious 'clunking' sound when shifting which I think is normal. Try the search function in the black bar at the top of the page,
FF
Old Jan 31, 2010 | 09:50 PM
patbras's Avatar
patbras
Hi Fascistfaction,
shocks are new, throttle body is completely cleaned and there still is a Vibration that feels like driving over rumble strips while driving at a steady speed?
What could that be?
Old Feb 1, 2010 | 02:19 PM
1969CoronetR/T
vaffanculo
Check your harmonic balancer in the front of the engine as it may need replaced and will cause the engine to vibrate,
FF
Old Feb 1, 2010 | 02:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
patbras
Did you ck the driveshaft to see if you missing a weight or bend shaft? And also ck the rear york for loose bolts or nut the pinion shaft. You could also have bad u-joints or a problem with one or more of your tires too. And like fasistfaction had mention ck the harmonic balancer too.
Old Feb 1, 2010 | 03:29 PM
Mystro's Avatar
Mystro
Its not a certain RPMs like say 1800-2000?? That is when the Hemi exhaust drone comes in and sounds like that. There is a TSB on a fix.
Old Feb 2, 2010 | 10:59 AM
patbras's Avatar
patbras
mystro, no specific rpm
Old Feb 2, 2010 | 11:00 AM
patbras's Avatar
patbras
what is a harmonic ballancer and wher do i find it aand see if it needs replaced?
Thanks for all yoour help so far, much appreciated
Old Feb 2, 2010 | 12:31 PM
1969CoronetR/T
vaffanculo
It is a pulley connected to the crankshaft in the front of the engine. It counteracts the engines resonant vibration at certain RPMs. Check out this thread (Coal Train last post):
https://dodgeforum.com/forum/dodge-c...r-problem.html
FF
