2nd Gen Durango 2004 - 2009
Drive Belt
Old Mar 4, 2010 | 01:07 PM
JZRango's Avatar
JZRango
Default Drive Belt
Could someone help with the drive belt? How do I remove the belt?
Old Mar 4, 2010 | 05:01 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
What size engine do you have? You can go to Dayco website and download an illustration:
http://www.daycoproducts.com/daycowe...f!OpenDocument
FF
Old Mar 5, 2010 | 11:18 PM
hydrashocker's Avatar
hydrashocker
Welcome to the forum!!!!!
There is a pulley that has keeps tension on the belt (Belt Tensioner Pulley) as the belt goes around. You simply pull this tension off and remove the belt. In case you forget the order on how to replace the belt (through each pulley) there is a diagram under the hood on a sticker. The best belt is a Goodyear Gaterbelts and I know Auto Zone sells them.
Old Mar 9, 2010 | 11:11 AM
JZRango's Avatar
JZRango
The tensioner has 2 pulleys which is the one that I have to move? How do I remove the Tension By hand or with tools?
Old Mar 10, 2010 | 11:50 PM
hydrashocker
You move the pulley that has the spring arm on it creating tension. You pull it back with whatever tool is necessary to relieve tension then remove the belt.
