2nd Gen Durango 2004 - 2009
Temp guage
Old Jun 16, 2010 | 06:24 PM
89ram150's Avatar
89ram150
Default Temp guage
I have an '04 2wd w/ 4.7 and 85k miles. I've been having issues with it seeming to run a little hotter than I would like. The needle on temp guage spends most of its time in the upper half, which I'm just not used to seeing in any of my previous vehicles. I thought that perhaps the thermostat was starting to get hung up, so I changed it and "burped" the system. It's running exactly where it was before. The fan clutch kicks in like it should, and there are no leaks. So I guess my question is, is this just where they run? I know factory guages aren't the greatest (especially with no numbers), I just don't want to see this thing blow up. I have an '89 Ram with a 318 and atleast 125k miles, it has a thermostat, and even with the a/c on the guage doesn't move much past C and the fan clutch never kicks in.
Old Jun 16, 2010 | 08:19 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Try these two earlier threads:
https://dodgeforum.com/forum/2nd-gen...-problems.html
and
https://dodgeforum.com/forum/2nd-gen...ng-or-not.html
FF
Old Jul 18, 2010 | 10:04 PM
martin66's Avatar
martin66
no smoke out the back had the same problem no leaks but loosing antifreeze a little at atime had my coolant checked for gases in it and it was a head gasket going got it fixed and now doesnt even go near the half way mark even in the hotest wheather
