Front end clunk
Front end clunk
For those of you experiencing a dull clunk and slight feel coming front the front end, I had the same problem. I heard a dull clunk coming from the front end and initially though it was a CV joint problem or some other suspension / axle problem. I took it to the dealer and they could not find anything wrong. I found the fix and it was very simple. It seems the problem was the front sway bar bushings. Just spray on a little lubricant (I used motorcycle “Chain Wax”, which retains a film covering). The problem was immediately gone and has not come back. Any quality lubricant will do and it took me about 1 minute. It also helps the bushings from dry rotting.
