noise in Durango front end
It is likely the suspension bottoming out on the bump stops or the sway bar links and bushings. replace shocks and have your alignment guy crank up the torsion bars to lift up the suspension a bit.
You also have to make sure that those new sway bar bushings are greased really well or they will pop and bang when turning or going over bumps, spary some silcone spray or something on them.
