2nd Gen Durango 2004 - 2009
Help with Durango Problem
Old Nov 4, 2010 | 05:22 PM
Sysco462's Avatar
Sysco462
Default Help with Durango Problem
I am new here so I have not had a lot of time to search the threads for this issue. My wife has a 2005 Durango 4x4, I think 4.7. The engine revs up and down at stops, the rpms jump from 2 to 3 rpms while driving down the road, shifting is rough slowing and starting up, sometimes the engine dies at stops, and the engine stalled on her the other day. I thought it was the transmission but I took it to my transmission guy and he said a TPS sensor code was the fault. He did not know much about this so he referred me to a mechanic. I can't get in to see him until next week. Does it sound like I need a new TPS sensor? If so, is it easy to install?
Thanks for your help.
Old Nov 4, 2010 | 06:01 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The TPS needs replaced and look at the IAC:
https://dodgeforum.com/forum/2nd-gen...age-check.html
FF
Old Nov 5, 2010 | 09:16 AM
Sysco462's Avatar
Sysco462
What kind of cost should I expect from the mechanic to change the TPS?
Old Nov 5, 2010 | 01:12 PM
1969CoronetR/T
vaffanculo
I would guess an hour to replace plus $30.00 for the part,
FF
Old Nov 5, 2010 | 02:01 PM
Sysco462's Avatar
Sysco462
I went to the mechanic. He said I had a stored TPS sensor code (P0068). He reset it and drove it. He said it drove perfectly and to bring it back if it starts messing up again. Does this sound legit?
Old Nov 5, 2010 | 03:17 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sure, if the connection was loose or dirty weird things happen, if it comes back quickly that means there is a problem and it was not a fluke, if it stays off for a long while and comes back on id repeat the procedure.
however shops usually wont tell you that, they will just replace the part and charge you for it
Old Nov 7, 2010 | 12:10 AM
master tech's Avatar
master tech
Site Moderator & Tech
Symptom:
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- VACUUM LEAK DETECTED
When Monitored and Set Condition:
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION - VACUUM
LEAK DETECTED
When Monitored: During all drive modes.
Set Condition: If vacuum drops below 1.59Hg with engine RPM greater than 2000 RPM
and closed throttle.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
VACUUM LEAK
RESISTANCE IN (K6) 5-VOLT SUPPLY CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (K6) 5-VOLT SUPPLY CIRCUIT
MAP SENSOR
RESISTANCE IN THE (K1) MAP SIGNAL CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (K1) MAP SIGNAL CIRCUIT
RESISTANCE IN THE (K4) SENSOR GROUND CIRCUIT
TP SENSOR OPERATION
RESISTANCE IN THE (K7) 5-VOLT SUPPLY CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (K7) 5-VOLT SUPPLY CIRCUIT
TP SENSOR
RESISTANCE IN THE (K22) TP SENSOR #1 SIGNAL CIRCUIT
RESISTANCE BETWEEN GROUND AND THE (K22) TP SENSOR #1 SIGNAL CIRCUIT
PCM
If you need the rest of the pdf file send me a pm with your email address and i'll send it. This goes for anyone that wants it.
