2nd Gen Durango 2004 - 2009
2006 Durango stalls when cold
Old Feb 16, 2011 | 04:36 PM
kenuks's Avatar
kenuks
Default 2006 Durango stalls when cold
I have a 2006 Durango (Hemi)and it is only stalling when it is cold and at an intersection when I come to a stop. Once it warms up after a few minutes it is fine. I have seen it stall a few times at the same intersection when it is cold. If the outdoor temperature is below 32 degrees it is worse.
As soon as I come to a full stop I can see the tachometer flutter and then just drop off and the truck stalls. Restarts no problem right away.
Old Feb 16, 2011 | 05:27 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Check the idle air control valve, the mass air flow sensor, the EGR valve and you may need to clean the throttle body. Do any codes show up or a check engine light?
FF
Old Feb 17, 2011 | 07:54 AM
WhiteWidow00's Avatar
WhiteWidow00
I'm agreeing with FF on this and have a hunch it's due to the IAC getting stuck. I'd start by getting a can of throttle body cleaner and clean out the throttle body as well as cleaning out the IAC port.
Old Feb 18, 2011 | 08:46 PM
kenuks's Avatar
kenuks
I will try all of the above. I had an error code when I plugged in OBD.
P0734 - gear ratio error in 4th gear - I assume totally unrelated. guess I should check that out as well.
No lights on to indicate problem.
I will say that the weather has warmed up here to 40 - 50's last few days and I am still having problems. Not stalling as much however, fluttering at intersections when I come to a stop. Therefore not totally related to extreme cold. I originally thought that was the problem. It just appears to occur at any time the vehicle is cold.
Old Feb 25, 2011 | 02:11 AM
Davect06607's Avatar
Davect06607
I have been battling the same problem for awhile now.
Tends to stall more when cold.
So far have changed plugs, Throttle position sensor, EGR valve (what a pain in the ***) and ran numerous brands of fuel injector cleaner. Throttle body is squeeky clean.
Still no luck.
One thing I noticed though, was after changing the egr valve, i reset computer (by disconnecting battery for 10 minutes). And it ran perfect for 2 days! Then the symptons are back.
Idle air control valve is next to be changed, we'll see.
Old Feb 25, 2011 | 07:43 AM
1969CoronetR/T
vaffanculo
Somebody mentioned replacing the EGR gasket as well as the valve itself,
FF
Old Feb 25, 2011 | 09:16 PM
Davect06607
FF
The valve to block gasket was replaced, the tube to valve gasket was reused (was perfectly good though).
I just wonder why it ran perfect for 2 days when I reset the computer.
Old Mar 12, 2011 | 02:36 AM
Davect06607
Still no luck.
Idle air control valve has been changed, still doing it.
Not as much (due to warmer weather) but still stumbling idle and occasionally stalls.
Next is Crank Sensor, after that I have no idea.
Old Mar 17, 2011 | 11:57 AM
drunkinjun's Avatar
drunkinjun
I have a 2006 dodge durango limited with the 5.7 hemi. I am having the same problem. When cold the rpm will flutter and the engine will shut off at a stop. It does not seem to be so prevelant when the engine is warm and temp is warm outside however it will still do it occassionally. I have run sea foam through the port vac line and fuel tank. I looked inside the throttle body and it was pretty dirty. Alot dirtier than I though it should be. I cleaned it pretty well however still having the problem. I ran the OBD II and found a code for low pressure transmission however that is an easy fix with a little more trans fluid. What should I do?
Old Nov 13, 2014 | 10:53 AM
This guy over here's Avatar
This guy over here
I have all the same symptoms tried crank sensor and no help along with everything else you've posted. I'm leaning towards pcm or ecu either that or head gasket but no Signs of coolant in oil
