2nd Gen Durango 2004 - 2009
dodge durango 2004 SLT LIMITED Hemi.
Old Mar 3, 2011 | 04:27 PM
ftbllmom's Avatar
ftbllmom
Default dodge durango 2004 SLT LIMITED Hemi.
Hi there I'm new in this forum and I need some help with this car. Recently the engine,seat belt, abs & lightning light came on. Took it a dodge dealer told me pay $100 to diagnose. Now they did a simple test and the mechanic said it gave him 7 codes.Can someone help me please? I am not having any other issues excepts for the light. What am i looking at here with these lights. My nephew can do the repair..Thank you..
Old Mar 3, 2011 | 05:41 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second Generation Durango section. Turn the key from 'off'' to 'on' (not run), off to on and off to on and then look at the odometer. I will flash a P---- code or codes then will flash 'done'. Post those P codes,
FF
Old Mar 3, 2011 | 06:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or go to an auto parts store and get them to connect their scanner to the truck and tell you what the codes are. Write them down and bring them back here and post them.
Old Mar 3, 2011 | 11:51 PM
jasonw's Avatar
jasonw
Site Moderator
Yup, that same test that the dealership charged you $100 for will usually be done for free by most auto parts stores.
Old Mar 4, 2011 | 03:02 AM
ftbllmom's Avatar
ftbllmom
ok will call them in the morning for the codes. I didnt let them do the ones that they said it was going to cost me. But will post all the codes here. Thank you for your help guys..
I did what you asked about turning the key on and off without turning the car on, and I didnt get any codes. But will call the dealer tomorrow and get the codes then will post on here...
Old Mar 4, 2011 | 04:41 PM
n8ech's Avatar
n8ech
FBMom:
How old is your battery?
Our Durangos as as well as most Chrysler/Dodge vehicles are very sensitive to a failing battery. You need to have it load tested, and replace if it tests the least bit flaky.
Really weird things like you are seeing can happen in this case................Don
Old Mar 8, 2011 | 11:24 AM
ftbllmom's Avatar
ftbllmom
I purchased the car last year in feb, dont know if its the original battery or not. I got the auto zone guy scan for the codes and these are the ones I got,P0572,P0440 & P0441. I also had him do the test for the battery & the alternator he said the battery is ok it came up between 14 & 15. the alternator he said is also ok, but he explain that the lightning light might be something between the alternator and the battery connection so i dont know. The abs he said its a breaklight switch.. So what do you guys think?
Old Mar 8, 2011 | 12:39 PM
1969CoronetR/T
vaffanculo
Old Mar 8, 2011 | 01:09 PM
ftbllmom's Avatar
ftbllmom
any suggestion about the lightning light coming on every now and then?
Old Mar 8, 2011 | 04:03 PM
1969CoronetR/T
vaffanculo
The 2004 had a recall for the instrumnet cluster and I think it made the interior lights go crazy and pose a fire hazard:
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
