2nd Gen Durango 2004 - 2009
New member & need help!
Old Apr 30, 2011 | 10:53 AM
Hemi-Brian's Avatar
Hemi-Brian
Unhappy New member & need help!
New member down here in AL...& yes very near the devastation. Need some advice on why my D-Durango/Hemi wants to cut off during rain and car washes??? Hemi-Brian
Old Apr 30, 2011 | 01:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out our Durango Section!!
Dusty
Old Apr 30, 2011 | 02:57 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Durango section,
FF
Old Apr 30, 2011 | 07:02 PM
red hemi durango's Avatar
red hemi durango
had the same problem built a sheild over the throttle body and spark plug leads and coil packs problem solved , if you want pic send me email address
Old May 1, 2011 | 10:30 AM
rojawajr's Avatar
rojawajr
Default Wet and not so wild
Newer vehicles almost all react bad to the introduction of water. Manufacturers go through quite a bit of trouble to figure out how to keep the water out. High pressure water from car washes and severe showers can often get into the car's electronics causing a multitude of problems.
I had this same issue on a Chevy Monte Carlo and a 94 Grand Cherokee,
Try locating the source(s) of water intrusion. Common areas on the D include the Windshield Wiper/Rear Hood area, and Sunroof. Other areas that can be a concern are the Front wheel wells and behind the headlights.
Check for missing rubber seals, missing/cracked plastic covers over fuse/relay boxes, wheel well liners and don't forget to check for water intrusion into instrument/dash area from the sunroof drains.
Also be sure to check the boots around the spark plug wires.
Replace seals and parts as needed. There are also some Electrical Contact cleaners and Protective Sprays that may help.
Good luck and welcome to the forums.
Old May 3, 2011 | 08:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
