2nd Gen Durango 2004 - 2009
04 durango 4.7 misfiring!
Old May 8, 2011 | 01:49 AM
jasonw's Avatar
jasonw
Site Moderator
Did you check the fuel pressure (or have it checked) yet?
Old May 8, 2011 | 09:38 AM
gonzo9191's Avatar
gonzo9191
ALL the drivers side coils aren't working. i had it running and unplugged each coil. all 4 on the driverss ide didn't change the idle, when i unplugged the passenger side, the idle went lower and chugged more.....
any ideas?
forgot to check pressure, it has fuel as the shrader squirts good.
Old May 8, 2011 | 04:10 PM
jasonw's Avatar
jasonw
Site Moderator
Some fuel doesn't mean its the proper amount. Pressure check is the only way to tell for sure.
Did you test the coils? Test them (multimeter required) to see if its the coils or somewhere before the coils thats failing.
Old May 8, 2011 | 09:10 PM
gonzo9191's Avatar
gonzo9191
whats the test method, i ohmed them out and got a similiar reading between all 2.3 ohms accross terminals on connector....
thanks donn
Old May 9, 2011 | 02:30 AM
jasonw's Avatar
jasonw
Site Moderator
Test one (or all) of the coils on the good side. If they all have the same resistance (ohms), or very close, odds are you haven't found the problem, just a symptom of the problem.
Old May 9, 2011 | 10:56 PM
n8ech's Avatar
n8ech
Gonzo:
Have you had the battery load tested yet? I know you say it cranks well, but these Durangos are very sensitive to a dead/dying battery.
Have you ever had to keep your foot on the gas pedal to keep it running?
Don
Old May 9, 2011 | 11:51 PM
gonzo9191's Avatar
gonzo9191
hello, i have not had to keep my foot on the pedal to keep it running.....you can feel the miss at idle in park, when you put it in drive or reverse, the whole car shakes.
