2nd Gen Durango 2004 - 2009
Central timer module
Old May 24, 2011 | 08:37 PM
firsttimedodge's Avatar
firsttimedodge
Default Central timer module
Where is the central timer module located on a 2006 dodge durango 4.7
Old May 25, 2011 | 10:21 PM
n8ech's Avatar
n8ech
FTD:
There were leaps and bounds in the technology between the Gen 1 and Gen 2 Durangos.
I don't believe the Gen 2 has a CTM per se. There are many more computers on the Gen 2. Possibly this function is done by the Forward Control Module. The instrument cluster is also a very complex computer as well and may be involved to name a few.
Don
Old May 26, 2011 | 07:36 PM
firsttimedodge
Originally Posted by n8ech
FTD:
Don
I have already changed the FCM and it was not that
Old May 26, 2011 | 09:25 PM
n8ech's Avatar
n8ech
FTD:
What issue(s) are you having? I have an 04 FSM and will try to find out what module controls the section giving you fits.
Old May 27, 2011 | 12:12 PM
firsttimedodge
I have a 06 Durango 4.7 SLT. I noticed my battery was dead every morning. I replaced the battery and still had the same problem. After doing some checking I realized my radio and or display was staying on regardless of wether or not the key was in the ignition. I also realized my wipers would continue to work without any key as well as the windows. I was thinking it may be the FCM but I already replaced it with no results. I have also changed out the relays and still nothing. Any suggestions
Old May 27, 2011 | 12:16 PM
firsttimedodge
I was thinking a ctm or a door module if there is one?
Old May 27, 2011 | 10:00 PM
n8ech's Avatar
n8ech
FTD:
Sounds like a relay somewhere could be sticking. Also could be a bad ignition switch. Wife's 05 Caravan was doing weird things like this, and the IGN switch was worn out.
Will check my FSM for you to see what it reveals.
Don
Old May 31, 2011 | 02:50 PM
firsttimedodge
Default You got it!!!
Bingo!!!! Bad ignition switch, Thanks alot
Old Jun 2, 2011 | 10:05 PM
n8ech's Avatar
n8ech
FTD:
Glad to hear you found the problem!
It's always nice to remedy and issue like this on our own.
Don
