2nd Gen Durango 2004 - 2009
DTC P1128 and P1129
Old May 27, 2011 | 07:09 AM
saulshafer's Avatar
saulshafer
Default DTC P1128 and P1129
New to this forum and was looking for some help. Did a tune up on my Durango Limited with the 5.7. Oil change, New plugs, Champion iridium, New O2's all 4 and PCV. Also change the EGR valve. Now I'm have DTC P1128 and P1129 coming up. I replaced the front O2's (even though they were new) again finding that this was the problem on other websites. I also know the codes are...
P1128 - CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129 - CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
Please help
Thanks
Old May 27, 2011 | 06:35 PM
jasonw's Avatar
jasonw
Site Moderator
What brand of sensors did you use?
Old May 27, 2011 | 09:01 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
https://dodgeforum.com/forum/3rd-gen...ode-p1128.html
MAP sensor or some sites reference the MAF sensor?
FF
Old May 27, 2011 | 11:26 PM
jasonw's Avatar
jasonw
Site Moderator
Don't think our engines (any of them) have a MAF sensor, just a MAP.
Old May 28, 2011 | 12:26 PM
saulshafer's Avatar
saulshafer
I used Bosch both times. I know these engines have problems with Bosch spark plugs. But didn't think that the O2's would a problem.
Old May 29, 2011 | 04:35 PM
jasonw's Avatar
jasonw
Site Moderator
Its not necessarily a problem with our vehicles and Bosch units, its just the fact that Bosch has very low quality standards when it comes to their O2 sensors. There is a reason they are the cheapest everywhere you go.
www.rockauto.com
They have the Denso OEM factory units for under $40, IIRC. Much cheaper than going through a $tealership, and the same sensors.
Old May 30, 2011 | 01:37 PM
saulshafer's Avatar
saulshafer
Yeah just sucks. Already have $150 in O2's in it. Think I'm going to drop it off at the dealer to have a diagnostics done so I'm not chasing my tail. My front AC not working also. Get it all taken care of at once.
Old May 30, 2011 | 03:54 PM
jasonw's Avatar
jasonw
Site Moderator
My two cents: Find a trusted shop to take it to. Meineke is a good one in my area. Far cheaper than a $tealership. Dealerships are not any better than a good, local shop.
Old May 31, 2011 | 12:47 PM
saulshafer's Avatar
saulshafer
Well it was the MAP sensor. Plus found that I have a bad AC Pump, Plugged expansion valve to the front AC and bad Dryer. YAY!!
Installed MAP. Will see if that takes care of it in a day or two.
Old Jun 1, 2011 | 02:29 PM
saulshafer's Avatar
saulshafer
MAP didn't fix it. Back to the dealer it goes.
