2nd Gen Durango 2004 - 2009
my 04 durango hemi stalls when it rains
Old May 30, 2011 | 10:05 PM
nicks 04 durango's Avatar
nicks 04 durango
Default my 04 durango hemi stalls when it rains
my 04 durango hemi stalls when it rains hard or when i take it through mikes express car wash ill have too keep my foot on the accelerator at 1000 rpm to keep from dieing
Old May 31, 2011 | 02:23 AM
IndyDurango's Avatar
IndyDurango
Hey Nick!
Brownsburg here, you?
Check the wiring/coil connection nearest the air intake for getting wet.
IndyDurango
Old May 31, 2011 | 10:05 PM
nicks 04 durango
Danville, thanks ill give that a try.
Old Aug 11, 2011 | 10:23 PM
MizMo's Avatar
MizMo
I am having the same problem among 480 people on google. Please post your result and let us know if it works. We are tired of giving awaying money. Thanks
Old Aug 13, 2011 | 10:04 PM
n8ech's Avatar
n8ech
There is a known TSB out for a bad cowl piece on the early Gen 2 D'sthat allows water to run down on the engine when water comes down the windshield.
I do not have it handy, but have seen it posted here and elsewhere.
Definately not good to have water running down on the engine.
Don
Old Aug 14, 2011 | 04:35 AM
MoparMan1991's Avatar
MoparMan1991
But getting water on the engine wouldnt cause it to stall. I would lean more towards an exposed wire somewhere.
Old Aug 15, 2011 | 06:51 PM
mwebb's Avatar
mwebb
Default Himi stalling
I have a Hemi and seen the problem. Get the garden hose out and pop the hood and see it for your self. Let the hose run water down the wind shield. It will not even slow down, right on the engine. This much water will stall any engine.
You can purchase a new redesign cowen from the dealer for around $120. Will need button kit and some RTV. Will fix the problem. If you look closely at the cowen right in front of the wind shield you will see where it is not even touching. It is like the sun warps it.
Thanks for all the good post on this forum has been most helpful.
Just one thing that I have found,
Hemi owner
Old Aug 16, 2011 | 08:58 AM
mattark17's Avatar
mattark17
My wife's '05 with the 4.7 did the same thing. I was at wits end. I took it to my local shop and they cleaned the battery connections and put some dielectric grease on the terminals. I can now drive through 18 feet deep puddle without it stalling. Ok not really but it has solved the issue for us.
Old Aug 17, 2011 | 05:09 PM
n8ech's Avatar
n8ech
Moparman:
While I agree with you that a minor amount of water getting onto an engine should not be an issue, going through a car wash or putting a garden hose on your windshield is another story.
Today's engines have more and more sensitive electronic systems that make them run. Most of this is put up high in the engine compartment for just this reason.
Another topic not mentioned yet is the chance that something might crack since engines operate around 200 degrees, and having water in the 50-80 degree range dumped on it is probably not the greatest idea.
As always..................................YMMV...... ...............Don
