2nd Gen Durango 2004 - 2009
front blower motor
Old Sep 10, 2011 | 08:28 PM
pgtek's Avatar
pgtek
Smile front blower motor
Hi All
I have a problem with my 2004 durango from blower motor
sometime it does not come on only when i hit a bump then it's start and sometime it works fine
also when i it comes on after a bump the speed of the motor seam to get more spped.
what could it be motor or resistor
and how to fix it
thanks
Old Sep 10, 2011 | 10:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
You can try a new resistor and see if you still have a problem or it may have fix the problem.
Old Sep 11, 2011 | 09:20 AM
pgtek's Avatar
pgtek
Default how to replace front blower resistor
thanks for the replied.
How do i replace the blower resistor
thanks again
Old Sep 11, 2011 | 03:50 PM
jasonw's Avatar
jasonw
Site Moderator
Go to your local Advance Auto or O'Reillys (or equivalent) and buy yourself a Haynes (Chilton would be acceptable) manual. It covers lots of little things like this.
While you are there, grab the resistor. Most auto parts places, if they don't have one on hand, can order one. If you don't mind waiting, Rock Auto is usually cheaper.
IIRC, its two screws/bolts on the bottom of the blower motor and disconnecting a wiring harness.
Old Oct 1, 2011 | 04:39 PM
pgtek's Avatar
pgtek
Default now air bag light is on
Hi
I did download the maintenance manual and recommed to disconnect the negative wire from the battery
i did and install the resistor and still the same problem and now the air bag light stay on in the dashboard and the display on the passenger side dash
when i run the blower i hear a humm in the air vent from the heater.
speed goes up and down not the same hi speed from when i bought the durango new
what's wrong
