2nd Gen Durango 2004 - 2009
Help understanding alignment...
Old Dec 11, 2011 | 03:52 PM
mH13021's Avatar
mH13021
Default Help understanding alignment...
'05 Durango SLT 4.7 AWD
Hi, I have recently had the alignment done. Had some issues I guess with the lower control arm bolts. Frozen. So they put the torch to it.... Anyway the truck was picked up and the steering has a slight tendency to veer right plus about a 4 degree offset in the steering wheel while driving straight. Now looking at the "printout" before & after, there is no correction happening in the passenger-side camber adjustment?!
There is a problem here and I am going to take it back to correct it.
I am just asking for opinions about being off a degree in a alignment spec and having the above issues calling this "aligned".
Thank you.
-Marty
_______________________________________
Click image to view large printout of alignment from the service center.
Old Dec 13, 2011 | 12:09 AM
master tech's Avatar
master tech
Site Moderator & Tech
Marty
Your alignment is so far out. Who was working on it? The left front camber is -1.0 should be 0.2, same thing on the right side.
Old Dec 13, 2011 | 07:28 AM
mH13021's Avatar
mH13021
Default Take a 2nd look...
Originally Posted by master tech
Marty
Thanks for the info, need to look at the "current" measurements below the "before" on the image attachment. Let me know what your thoughts are on those results.
Would you perhaps provide the alignment margins?
Thanks.
- Marty
