2nd Gen Durango 2004 - 2009
2004 5.7L Durango Stalls in Rain
Old Dec 27, 2011 | 10:12 AM
tootallll's Avatar
tootallll
Default 2004 5.7L Durango Stalls in Rain
Have an '04 5.7L Durango that stalls in rain. It only stalls at stop or rolling speeds under 10mph. It may be pouring rain but as long as the Durango is moving there is no problem. Appears to be an issue of water getting into engine and fouling some component just can't figure out which one.
I've researched the prob and several people have experienced a similar problem. The fixes that have worked for others include: changing intake "O" rings; re-torquing/changing intake gaskets; changing spark plugs/wires.
There apparently is a TSB calling for replacement of the hood cowling to stem water draining from windshield unto engine but those that have had their cowling replaced said it did not fix the problem.
Just wondering if anyone has successfully corrected this problem with a fix other than the ones listed above.
Thanks!
Mike
Old Dec 27, 2011 | 01:31 PM
tinmanwpk's Avatar
tinmanwpk
The cowling leaks at the base of the windshield causing water to drip on the back plugs.
Old Dec 27, 2011 | 02:03 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
There are a few threads about this same problem due to the cowl 'leaking' and coil packs getting wet,
FF
Old Dec 28, 2011 | 09:52 AM
tootallll's Avatar
tootallll
Thanks for your replies. Saw some posts about the cowling before I posted but the posts I saw stated altering the cowling didn't help. Must not have found the posts you are talking about.
Mike
Old Dec 28, 2011 | 10:13 AM
tootallll's Avatar
tootallll
Did another search on the forum and still did not find anything about the cowling leaking onto the spark plugs...
Update: Searched your posts fascistfaction and found the link...thanks! The "D's" in the shop now, I'll tell'em to calk the cowling.
Old Dec 28, 2011 | 07:23 PM
1969CoronetR/T
vaffanculo
I should have linked them in my reply,
FF
Old Dec 29, 2011 | 10:22 PM
steak59's Avatar
steak59
The Cowl TSB only applies to the 4.7l Durango because The Coil pack seal is poorly designed. They revised the TSB that includes installing some umbrellas on the Coil pack. The Hemi is different.
Old Dec 30, 2011 | 12:55 PM
tootallll's Avatar
tootallll
Yeah, the dealer said he couldn't find a TSB on the cowl. Checked out the cowl and there is a piece of rubber weather stripping along the top of the cowl that was tore up. Ran some water down the windshield and it just pored into the engine. Had the dealer calk it...should solve the prob...will test when I get a chance.
Thanks for your help!
Mike
Old Jan 3, 2012 | 09:59 AM
tinmanwpk's Avatar
tinmanwpk
You're welcome. Glad you got it right.
Old Jan 7, 2012 | 07:13 PM
Daddytomykids's Avatar
Daddytomykids
Just saw this post, i put a thread on here ,
Wish i woulda known about the cowl problem before my engine hydrolocked, i put a video on my thread.. Dodge should recall this and pay for repairs in my opinion.
https://dodgeforum.com/forum/2nd-gen...oken-rods.html
