Cause of poor gas milage w/5.7L MDS engine?
Trending Topics
Mike:
+3 on the overhead console not being very accurate. You should find that you can use the reset button to bring this reading back to zero for a fresh reading, but the old gallons used per tank vs miles driven is still the best method.
Re the MDS, depending on your personal driving style, you may see little to no difference in the mpg of your D.
Hopefully you are running the required 5w20 weight oil so the system can work as designed.
Your best shot at seeing good mpg will be steady state cruising (no towing) on the highway. Some folks have reported 21-22 mpg with MDS under these parameters.
If you are lead footed, keep a lot of crap inside, or live in a mountainous area, the MDS will engage rarely.
My 04 Hemi SLT usually returns 13 mpg around town and 16-18 mpg hwy depending on how my luck is running.
This is with the 3.55 gears. Don
