2nd Gen Durango 2004 - 2009
transmission issue
Old May 18, 2012 | 08:07 PM
wags70ss's Avatar
wags70ss
Default transmission issue
I have an 06 durango with codes po700 & po841.
it is acting funny when you shift into drive. I read you can replace the sump filter & the cooler filter & this may eliminate the problem.
Can someone tell me where the cooler filter is located? i have checked the cooler lines from the cooler to the transmission & see no filter anywhere. Is it inside the pan?
Old May 28, 2012 | 12:21 AM
master tech's Avatar
master tech
Site Moderator & Tech
When was the last time you had the transmission service?
Old May 31, 2012 | 09:34 AM
wags70ss's Avatar
wags70ss
Actually, I took it to a trans shop & for $95 they replaced both filters & the fluid & the problem is gone now. They told me the filters used by Dodge tend to crack internally & that causes this isuue. It is fixed now. Thanks!
Old Jun 1, 2012 | 11:30 PM
n8ech's Avatar
n8ech
Wags:
I believe the sump filter is the culprit in that situation. $95 is a good price for a fluid/filter drain and refill these days.
I think the dealer gets $165 or more nowadays.
The 7 quarts or so of ATF+4 is $7 each and the filter kit can be as much as $45.
You should be doing this every 50K if you drive normally, and 35K if you tow a lot and heavy.
Autozone has a really nice Duralast filter kit part #TF98 for the 45RFE/545RFE trans and they get $14 for it!
You also get the seal for the sump filter along with a pan gasket.
I recently used one of these and was very satisfied with the quality of it.
Dodge recommends RTV as a gasket, but I think its a PIA to clean off.
I will use the gasket instead.
Don
Old Sep 21, 2012 | 08:14 PM
ndtguy's Avatar
ndtguy
Originally Posted by n8ech
Wags:
Don
Don,
Did autozone give you the correct gasket? I tried to get one from them and they gave me one that didn't have any holes and was to small for the transmission in my wife's Durango. I had to use RTV instead.
If Autozone did give you the correct gasket, what type of gasket it was it? (Cork/Rubber/etc)
Thanks in advance.
Old Sep 25, 2012 | 11:21 PM
reject012's Avatar
reject012
no gears work. just like in neutral in all selections ????any ideas???
Old Sep 26, 2012 | 12:28 AM
master tech
Welcome to DF
I need a little more information, like did the transmiision just quit or did you just change the filters?
