2nd Gen Durango 2004 - 2009
Durango door won't open both manually and remotely
Old 06-24-2012 | 09:03 PM
bib's Avatar
bib
Default 2006 Durango doesn't unlock either manually and remotely
I think the battery might be dead, and I don't have access to the other set of keys (just yet). When I insert the key into the driver door (this door is the only manual access point) I am unable to turn it. Any advice?
I was able to access it manually a couple of days ago, but no longer.
Model: 2006 Dodge Durango Limited 2WD 5.7L Hemi
Old 06-24-2012 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
You can try some WD40 or light oil and try to turn the lock.
Old 06-25-2012 | 09:49 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I use a graphite lubricant on my warehouse doors.
Old 06-25-2012 | 10:20 AM
DodgeCares's Avatar
DodgeCares
Bib,
Are you using the same key you used a couple of days ago?
Old 06-26-2012 | 04:33 AM
bib's Avatar
bib
I lubricated the key, still nothing.
And yes, this is the same key I've been using for a while now.
The Durango was towed to the local dealership so it's in their hands now, I'll update when I hear from them.
Old 06-28-2012 | 07:33 PM
bib's Avatar
bib
So, dead battery plus door cylinders on drivers side were shot. 506$ including tow.
Old 06-29-2012 | 08:51 AM
1969CoronetR/T
vaffanculo
Why was the vehicle towed?
FF
Quick Reply: Durango door won't open both manually and remotely
