2nd Gen Durango 2004 - 2009
2004 Durango 4.7 Magnum Sea Foam Treatment
Old Aug 30, 2012 | 12:40 PM
aWanderer's Avatar
aWanderer
Default 2004 Durango 4.7 Magnum Sea Foam Treatment
Hi all,
My first post here. Thought I would share my experience with this Durango. I bought it used a few weeks back. I didn't know about the ticking noise on a cold start of course, until the next day. It ticks for about 5 minutes and after everything warms up, runs like brand new.
I did some regular maintenance on the truck. i.e.; diff seals, oil, rear brake job, etc. ($1,200 at the dealer). I then changed the plugs myself because a mis-fire on cal. 8 code was appearing (plugs looked like originals), changed the bulging rad hoses, air filter, etc.
Thought I would try this "Sea Foam" treatment, as some reported that it would resolve a sticky valve or lifters?... anyway, I put 40 litres gas in the truck (10 gallons), and made sure it was running at operating temps. I believe the application was good. I definitely notice some improvement in performance but the ticking is still there on cold start. Once it is warmed up, the truck runs like new.
It's the next day that I am posting this thread. Took it out for a drive and when I stop, put the truck in park, it stalls. No doubt, it is because of the Sea Foam still in the oil and tank of fuel... I hope. Anyway, here is my video.
Old Aug 30, 2012 | 01:26 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I use Seafoam followed by Chevron Techron after every oil change. Put a can in with an nearly empty gas tank. I use Marvel Mystery Oil at every fill up unless it is racing fuel in my Coronets.
FF
Old Sep 10, 2012 | 11:08 AM
aWanderer's Avatar
aWanderer
Thanks for the info fascistfaction. I'll try and find that Chevron Techron.
Well, truck is on a new tank of fuel now. Doesn't stall when I stop anymore. I believe the whole SeaFoam treatment helped a little but there is still ticking on a cold start. Guess I will have to live with it. Adding 1/3rd of the bottle to 40 litres of fuel was not enough; too much fuel in the tank. Should have added at least 1/2 to 3/4 of a bottle according to their site. So adding that small amount to that much fuel was pointless.
I am going to try another product that the NAPA guy said "people swear by this"... I just can't think of the name at the moment.
Old Sep 15, 2012 | 07:55 PM
1969CoronetR/T
vaffanculo
I use a once per gallon of gasoline. You can get the spray bottle to 'inject' into the upper cylinders per their website. I have poured it into the air intake manifold to my carbs on my Coronets, but not to my Durango.
FF
Old Apr 24, 2013 | 07:52 AM
aWanderer's Avatar
aWanderer
Default Update
OK, been almost a year now and I never did get rid of the ticking on cold start until a couple weeks ago. I took it in to the dealer and $1,700 later. Ticking is gone. Issue was the timing assembly.
I also noticed that the MPG is up. The L/100km use to sit at 21.5 and now, after a few tanks still, it is sitting at 18.5. Thats a 3L per 100KM savings. Not bad if you ask me. In addition, the truck is much more responsive as well.
The Seafoam never really did anything. I don't think that stuff is very much more than a gimmick.
Old May 9, 2013 | 08:17 AM
aWanderer's Avatar
aWanderer
Correction... after the timing assembly replacement, I am now getting 17.0 L/100km consistently.
Old Jun 4, 2013 | 10:25 PM
Bakerboys8's Avatar
Bakerboys8
Wow! I garauntee your ticking noise was an exhaust manifold bolt or two broken off. These engines are notorious for that and I just changed my bolts due to a ticking noise during cold starts. The ticking would go away after about five minutes. It's a shame but I think you got robbed.
Old Jun 5, 2013 | 08:05 AM
aWanderer's Avatar
aWanderer
LOL... I probably did on the price but not the diagnosis. We checked all the bolts a week or two before it went in and they were fine. Besides that, how would you explain the fuel savings? I don't think that changing the manifold bolts would have anything to do with that.
Old Jun 5, 2013 | 08:11 AM
aWanderer's Avatar
aWanderer
and for the record, the fuel economy is reading 16.3 L/100 KM now. Thats quite a difference from the 21.5 I got prior to the work.
Old Jun 5, 2013 | 06:23 PM
moe7404's Avatar
moe7404
i have nothing against Sea Foam. but i have used marvel mystery oil for 30 years. just my idea.
