2nd Gen Durango 2004 - 2009
Starter/solenoid Location
Old Nov 10, 2012 | 11:08 AM
jso911srv's Avatar
jso911srv
Default Starter/solenoid Location
My '06 durango won't start and before I spend the money to have it towed, what side of the engine is the starter located on '06 4.7 2wd so I can test it? I already know its not the battery, took it to two places to have it tested and both results where good, and the battery is only 3 months old.
I am having electrical issues and if I can get it started, I can take it to the dealer to check some recalls.
Old Nov 10, 2012 | 11:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Its under the vehicle on the driver side.
Old Nov 11, 2012 | 08:57 AM
jso911srv's Avatar
jso911srv
Thank you.
Another question I should have asked in the op. Like I said I am having electrical issues and I found out there is a recall for the instrument cluster wiring and I checked my vin and it is an open recall. Ocassionally my right rear turn blinker doesn't work like if the bulb is burnt out and it does the rapid blinking, other times it works fine.
Currently I can not get it to start, sometimes there is the rapid clicking and all the electronics work, then other times its completely dead and not one thing works like if there is no battery in the vehicle, and then there a few times when it cranks right up. Could it be a solenoid problem?
