2nd Gen Durango 2004 - 2009
Durango 2008 stop running engine
Old 11-20-2012 | 05:36 AM
LMADurango13's Avatar
LMADurango13
Default Durango 2008 stop running engine
Hi
My parent got Durango 2008 and it done over 200.000 km.
Now, the engine stop suddenly after driving a while from stop. When you return the gear to N position and start the engine again, it start normally. This happen so many times now. Has any one know why this occur and what is the solution??
thanks
Old 11-26-2012 | 11:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is the check engine light on? How is the idle, is it low? First thing i would do is replace the air filter and remove the throttle body and clean the blade.
Quick Reply: Durango 2008 stop running engine
