2nd Gen Durango 2004 - 2009
Pass Airbag Off
Old Mar 10, 2013 | 12:14 PM
jimspringer64's Avatar
jimspringer64
Default Pass Airbag Off
On my 2004 Durango, when I start up the engine the SRS light says "Pass Airbag Off" even when an adult is sitting in the passenger seat. It does go off after about 3-5 seconds. The light does not come back on at all, only when I first start the engine. Is my airbag turned off or is this normal?
Old Mar 10, 2013 | 01:57 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
The 2004 instrument cluster is recalled and can cause a fire. Call your dealer (or any dealer) with your VIN.
Go to www.safercar.gov for all recalls pertaining to the 2004 Durango.
FF
Old Mar 11, 2013 | 06:50 AM
jimspringer64
Ok Thanks!
Old Mar 12, 2013 | 01:52 PM
roy rogers's Avatar
roy rogers
Its normal. Turn the key, pass airbag off light on, after a few seconds the light goes off. If the light is off it means that the system is active. If you place a little pressure on the seat such as a bag of groceries or whatever - i think its 85 lbs or less the light will come on - pass airbag disabled - this is by design in case you have a child on the front seat.
rr
Old Mar 12, 2013 | 06:24 PM
jimspringer64
That is what I thought too. Thanks for the info!
Old Mar 12, 2013 | 07:59 PM
1969CoronetR/T
vaffanculo
Still check the recalls with your dealer.
FF
