2nd Gen Durango 2004 - 2009
Timming help 04 4.7l
Old May 7, 2013 | 07:30 PM
signsnow08's Avatar
signsnow08
Default Timming help 04 4.7l
I just got through putting together a 2004 dodge durango 4.7 timming set. All the guides,tensioner arms and chains were worn out but it was still running. Before i tore it down i set ll the timming to specs and marked everything. When i firied it up it sound like one of the tensioners were making noise as if it wernt pumped up with oil and it also spits back it u accelerate hard. So i think maybe the timming is off but i cant figure out how. The check engine light is also on now, any help would be appreciated.
Old May 8, 2013 | 02:36 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Just curious, but what code shows up with the check engine light?
FF
Old May 14, 2013 | 10:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you take the spocket off the idler shaft?
