2nd Gen Durango 2004 - 2009
Pcm retrain
Old May 8, 2013 | 09:20 AM
spartacusrides's Avatar
spartacusrides
Default Pcm retrain
My 04 durango 4.7 threw a shift solenoid code and i replaced the solenoid. It seemed to help but it still was having trouble shifting so i reset the pcm. It still shifts a little rough in low gears. I know there is a certain amount of time it takes the pcm to relearn but how long is that? Should the check engine light stay on?
Old May 8, 2013 | 09:50 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Disconnect the negative terminal on the battery for a half hour and then press the brake pedal a few times to reset the system.
FF
Old May 9, 2013 | 08:38 AM
spartacusrides
But after i reset the system how long should it take to relearn? And should the check engine light still be on?
Old May 9, 2013 | 09:31 AM
1969CoronetR/T
vaffanculo
No the light should not be on.
FF
Old May 9, 2013 | 12:51 PM
spartacusrides
Is there any way to test the relays for the transmission or the pcm to see if they are bad without just replacing them? The relays are cheap but obviously the pcm is not.
Old May 9, 2013 | 01:36 PM
1969CoronetR/T
vaffanculo
What codes are showing? master tech is a transmission expert so he may be able to help you.
FF
Old May 9, 2013 | 03:59 PM
spartacusrides
Im getting the code for bad 2nd gear ratio now. I thought because i reset my pcm it was throwing that code cause it was still trying to relearn the gear ratio or that the transmission shift relays were bad
Old May 10, 2013 | 03:45 PM
1969CoronetR/T
vaffanculo
It may need rebuilt. I got a a similar code for my fourth gear ration and it cost me $3200.00.
FF
Old May 10, 2013 | 04:25 PM
spartacusrides
Ok so i replaced the input/output speed sensors thinking it could have been that but my durango still feels like its taking off in 2nd gear. I dont know what else it could be besides electrical at this point?
Old May 11, 2013 | 07:35 AM
1969CoronetR/T
vaffanculo
You could try to PM master tech (site moderator) as he is the transmission expert.
FF
