2nd Gen Durango 2004 - 2009
Quick trans question
Old Jun 6, 2013 | 06:07 AM
Challenger383's Avatar
Challenger383
Default Quick trans question
Does 5-45RFE trans require a new spin on filter as well as the usual sump filter and gasket?
I am just about to order a service kit, to do the job, but not sure if my transmission has a spin on filter, it's just a normal 2005 RWD Hemi .
And how do you know if you have a deep or shallow pan?
Thanks
Old Jun 6, 2013 | 08:47 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I believe it is internal.
FF
Old Jun 7, 2013 | 10:27 AM
Challenger383
Someone has mentioned that the deep pan is on 4X4 Durango's, does anyone know if that's true?
Anyone got any info on the spin on/off filter and whether is worth changing at the same time
Old Jun 9, 2013 | 12:54 PM
n8ech's Avatar
n8ech
Challenger:
Your 545RFE trans has 2 filters. The sump filter AND the mini canister return filter.
Both are located inside the trans pan.
Autozone has the Duralast TF98 filter kit that supplies both filters for $14!
Change them both and be sure to go back in with a good grade of ATF+4 trans fluid.
Don
Old Jun 10, 2013 | 09:27 AM
Challenger383
still don't know deep or shallow pan,
Pretty much thought as much on the spin on/off filter.....Thanks
Old Jun 10, 2013 | 10:41 AM
n8ech's Avatar
n8ech
Challenger:
I had heard that the 2wd trans may have the shallower pan. When I look up the filter kit on the AZ website though, it specs the same TF98 filter kit for the 4wd as the 2wd.
Don
Old Jun 11, 2013 | 03:34 AM
Challenger383
Thanks Don,
Ho Hum!!! Thanks again. Why do Chrysler/Dodge have to complicate the issue when surely the production of a deep pan to cover all applications would have been sufficient and easier for all concerned.
Going to have to try and dig deeper before ordering, as they are expensive in the UK. Bearing in mind the cheapest i have been quoted for just the flat filter and gasket is £40, but have been asked the dreaded question, deep or shallow pan.
There must be some kind of measurement you can physically take of the pan to make sure you get the right on
Ade
Old Jun 11, 2013 | 10:19 AM
n8ech's Avatar
n8ech
Ade:
I measured the deepest part of my trans pan this morning, and the driver's side towards the front was between 2.25 and 2.5 inches tall.
As you will see, this pan is large and requires a large catch pan when doing a fluid/filter service.
Hope this helps you.............................
Don
Old Jun 14, 2013 | 03:18 AM
Challenger383
Thanks,
I'll check the measurement on mine today, in theory it should be shallower than yours.
Being not up to date on our model range, does the Durango come in RWD, and AWD, and 4X4, or just the first 2 options.
Old Jun 14, 2013 | 11:14 AM
1969CoronetR/T
vaffanculo
Mine is AWD all the time with the option of 4x4 (high and low).
FF
