2nd Gen Durango 2004 - 2009
Need Advice
Old Dec 29, 2013 | 07:29 PM
Kajukenbo13's Avatar
Kajukenbo13
Default Need Advice
My radiator cap was leaking on my 2007 Dodge Durango so I replaced it . Then it started leaking from the lower radiator hose then that stopped and it stared leaking from the reservoir bottle and sometimes it looks like its leaking from the water pump area ? Any advice on what could be causing it to leak from different areas ? Water pump going out ??? Thanks !
Old Dec 29, 2013 | 07:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would have the cooling system pressure check to see were all the leaks are coming from. I know the spring clamps crap on the radiator hose's, but that what the factory use's.
Old Jan 4, 2014 | 06:01 PM
Kajukenbo13
Default Thanks
Well it turned out to be the water pump and after some wrenching the new pump is good .
