2nd Gen Durango 2004 - 2009
06 4.7 Durango slt revving on its own
Old Mar 13, 2014 | 09:36 AM
DrivingDurangorous's Avatar
DrivingDurangorous
Default 06 4.7 Durango slt revving on its own
Lately I started to notice every now again not everyday when I start the car put it in park or at a red light it revs up on its own then idles down revs up idles down to about maybe 1600 1700 rpm could this be a dirty throttle body.
Old Mar 13, 2014 | 12:22 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
It can not hurt to clean it.
FF
Old Mar 13, 2014 | 02:11 PM
JoshSlash87's Avatar
JoshSlash87
Throttle position sensor...buy a new one, its a common 4.7 problem. My sisters went out on her Durango 3x in 2 years. That will fix the issue.
Old Mar 13, 2014 | 05:47 PM
DrivingDurangorous
is the TPS easy to locate and replace
Old Mar 14, 2014 | 09:30 AM
1969CoronetR/T
vaffanculo
I believe it is on the side of the throttle body.
FF
Old Mar 14, 2014 | 03:42 PM
DodgeCACares's Avatar
DodgeCACares
DrivingDurangorous,
I'm sorry to hear about your idling issues. In some cases, an erratic idle can be caused by low transmission fluid. Have you had an opportunity to check and/or top off your fluids?
Old Mar 15, 2014 | 07:48 AM
DrivingDurangorous
I check the fluids weekly but I will check again thank you I think im also going to replace the TPS
Just to be on the safe side just for the fact they are common to go bad and have no idea when was it last replaced
Old Mar 16, 2014 | 06:48 AM
JoshSlash87
Originally Posted by DodgeCACares
DrivingDurangorous,
In some cases probably but that's more like a 1 out of a 50,000 chance if not higher, plus if it was that you'll more than likely hear the transmission pump whining at the same time the idle problems are happening but the symptoms described in this thread scream classic TPS failure.
To the thread starter, please change the damn TPS already instead of checking fluids....waste of time putting this off any longer, spend the $30 on the tps and enjoy your Durango again!.
Old Mar 16, 2014 | 08:59 AM
1969CoronetR/T
vaffanculo
Calm down Josh
