2nd Gen Durango 2004 - 2009
HELP!!!! stalls and hesitates
Old May 12, 2015 | 02:37 PM
akriner1's Avatar
akriner1
Default HELP!!!! stalls and hesitates
I own a 2008 dodge Durango , it recently has had a new motor put into it due to a cracked block. I have had it to the dodge dealer several times, they say there is nothing they can find wrong with it. I am frustrated with them. Anyone have any ideas.2008 Dodge Durango 4WD V8-5.7L
Old May 12, 2015 | 02:50 PM
Check engine light on? When you say "new" motor, it was brand new? Who installed it? Why not go to the place that installed it and make them work on it until it's right?
Old May 13, 2015 | 05:36 AM
akriner1's Avatar
akriner1
no codes, it was a mopar new engine installed by a local dodge dealer, been fussing with them since October. getting frustrated.
akriner1's Avatar
akriner1
they have had it more than me since October.
Old May 13, 2015 | 07:35 AM
Well they need to fix it. Try a different garage if you are not getting the results. I assume it came with a warranty?
Old May 13, 2015 | 11:52 AM
DodgeCACares's Avatar
DodgeCACares
akriner1,
How often is the vehicle stalling? Have you noticed any common tendencies when the issue occurs (coming to a stop, after an extended idle..)?
Old May 13, 2015 | 07:49 PM
akriner1's Avatar
akriner1
stalls once or twice a week at slow speeds for example while turning into a parking spot, hesitates for 1-2 seconds when starting at a stop sign, it acts like it wants to go, you can feel it start to accelerate then it bogs down before going,
Old May 13, 2015 | 07:54 PM
akriner1's Avatar
akriner1
dealer can reproduce it with a computer connected however all the data reported to their computer is "normal with no indications of problems ". the dealer acts like I am a nuisance. Yes it has a warranty.last time I was in the shop he sent it to the mechanic with a description of "engine runs poorly".
Old May 14, 2015 | 09:25 AM
DodgeCACares
akriner1,
With the symptom reproduced at the dealer, I would recommend a follow-up with the Service Manager and technician involved for further explanation. If the vehicle is stalling and detail of the event are recorded, your dealer has the resources available to review.
Old May 15, 2015 | 12:42 PM
akriner1's Avatar
akriner1
