2nd Gen Durango 2004 - 2009
2005 Dodge Durango 5.7 Hemi will crank no start
Old May 14, 2017 | 08:25 PM
Cheyenne's Avatar
Cheyenne
Default 2005 Dodge Durango 5.7 Hemi will crank no start
This durango will crank but not start unless you hold gas petal then once it start it runs rough and wont idle as soon as you let of gas petal it chugs out and dies. I have replaced fuel pump, fuel pump relay, thortle body, and cps. I have cleaned grounds and added grounds. Tested ohms on injectors and coil packs they checked out fine. Tested the injector wiring harness connectors. Relerned the cam and crank sensor. Recalibrated throtle body. Bypass the asd module. Need some advice what to do next other than burn it..
Old Sep 26, 2018 | 03:42 AM
DannyDF's Avatar
DannyDF
did you figure it out?
Old Sep 26, 2018 | 03:15 PM
After a year and some change, and not being here in over a year, I would suspect it's either fixed, or scrapped. Don't expect a response......
Old Sep 27, 2018 | 10:18 PM
DannyDF's Avatar
DannyDF
i was hoping he would get an email notification and come back and respond.
Old Sep 28, 2018 | 07:46 AM
Ever the optimist?
