2nd Gen Durango 2004 - 2009
Engine check light will not reset
Old 06-09-2017, 10:13 AM
Strongjm25's Avatar
Strongjm25
Strongjm25 is offline
Default Engine check light will not reset
Hello,
I Recently replaced the entire ac system in my 2006 dodge durango 4.7 slt 2wd. As many of you probably know you have to take the air intake off to reach the schrader valve when hooking up manifold guages to read and fill refrigerant. This is when the light came on. After finishing the repairs i disconnected the battery and held the key in the start position for 30 seconds, reconnected the battery and the light is still on. I had the code read and it is a tps sensor. I replaced the TPS about three months ago, and it is a fairly simple part so i dont think it has gone bad. The light on erks me any suggestions to get this light to reset?
Old 06-10-2017, 10:57 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,201 Likes on 2,953 Posts
What is the code? And did the TPS get unplugged while you were playin' with the a/c?
