2nd Gen Durango 2004 - 2009
After Market Battery Tray For Dodge Durango 2005
Old Aug 23, 2017 | 04:43 PM
SaintLaurent1's Avatar
SaintLaurent1
Angry After Market Battery Tray For Dodge Durango 2005
Does anyone know the tool used to remove the hold down bolt in the
original battery tray of a 2005 dodge Durango 4.7 V8. I've changed
numerous batteries before never seen a hold down constructed like
this. I Called 3 Dodge Dealerships service and parts department and
no one knew what tool to use for removal of the hold down bolt. Must
remove soon battery needs to be changed due to age. No longer
holding charge OEM Part #55362632AB PLEASE HELP. Thanks in
advance.
Old Aug 23, 2017 | 04:55 PM
SaintLaurent1
Thumbs down After Market Battery Tray For Dodge Durango 2005
Hello Dodge peolple. Does anyone know an aftermarket battery tray
which will fit a Dodge Durango 2005 4.7 V8, or a flat battery tray
which can be used with existing bolts and holes. OEM tray is poorly
constructed. Thanks
Old Aug 23, 2017 | 07:01 PM
I'll give ya that.
For my truck, I looked up the Dodge part number, and then did a google search on that. Came up with a LOT of options.
Old Aug 28, 2017 | 03:03 PM
Lamb's Avatar
Lamb
My 2005 4.7 Durango used a metric socket wrench on the battery hold down bolt, 8 or 10 mm, the bolt broke so I'll have to drill it out, I'm pulling the 4.7 after it overheated and warped the heads, thinking about putting a 5.7 in there while I'm at it
Old Aug 28, 2017 | 03:41 PM
Moved to the correct section.
