2nd Gen Durango 2004 - 2009
Best Battery for 2005 Durango 4.7L V8
Old Sep 9, 2017 | 04:22 PM
SRT8Durango!'s Avatar
SRT8Durango!
Default Best Battery for 2005 Durango 4.7L V8
What's going on Durango lovers!
Any other recommendations other than what I'm running now Interstate Mega Tron II MT-65 CCA 675, CA 845. I need more Cold Cranking Amps and Cranking Amps for a 2005 Durango 4.7L V8? Interior dome light has drained battery on 2 separate occasions when tail gate was left open for a short period of time (1 hour).
Thanks in advance.
Old Sep 9, 2017 | 09:48 PM
How old is your battery?
Welcome to DF! Check out the 2nd gen Durango forums.
Old Sep 9, 2017 | 10:00 PM
SRT8Durango!
Angry Battery
Thank you for your help. Battery is a 13 months old.
Old Sep 10, 2017 | 10:36 AM
have you had it tested??
Old Sep 10, 2017 | 11:02 AM
SRT8Durango!
Thumbs up Best Battery
Thank you for responding. Battery has been tested at Advance Auto Parts, Results were good. Just can not leave tail gate open for an extended period of time or battery will drain.
Old Sep 11, 2017 | 09:47 AM
That's likely going to remain the case, even with a new battery. Isn't there a switch to disable the lights?
Old Sep 11, 2017 | 10:02 AM
I cant imagine a dome light draining a battery in one hour....maybe replace the bulb with an LED one....
Old Sep 11, 2017 | 01:58 PM
Ken Garrett's Avatar
Ken Garrett
I also can't see a dome light draining a battery that fast. What voltage is your battery with the vehicle turned off should be around 12.6vdc? You might have a weak charging system or resistance in the charging circuit that isn't fully charging the battery. You should have at least 13.6vdc while the engine is running. I prefer to see 14+.
Old Sep 11, 2017 | 05:05 PM
Ken Garrett
And to answer your question. You can never go wrong with an Optima Red Top for normal auto applications.
