2nd Gen Durango 2004 - 2009
06- 5.7 fan clutch
Old Apr 15, 2018 | 05:19 PM
durangolimited06's Avatar
durangolimited06
Question 06- 5.7 fan clutch
I had to change radiator , fan clutch , belt .....it went well the fan clutch looks different but rock auto swore it was the part .
I changed it anyhow , now , after engine is shut off , & I restart it & put it in gear & go .....it sounds like the engine is revving high , according to the tachometer it is not revving high.....it just sounds like it ........I have the tow package & in some books it says it should have a heavy duty fan clutch , but that isnt available for this , .....I did find it for an 07 - 5.7 though ....its $50 to see if its the issue .....trans is good , not slipping & the tach is not showing a rev but it sounds like its a 4 barrel being kicked in
Old Apr 15, 2018 | 05:22 PM
durangolimited06
other than the sound in the first 1/4 mile .....it runs great & the temp is good & tach @ 1.5 .....
Old Apr 19, 2018 | 04:18 PM
now when starting to move , after engine is shut off ,
That part confused me.......
Old Apr 26, 2018 | 02:23 PM
durangolimited06
the loud noise mostly happens Only after first starting out , BUT ONLY AFTER the engine was shut off ,then restarted ..... it doesnt do it at stop lights or anything eles ....
Old Apr 26, 2018 | 02:40 PM
durangolimited06
if I move the truck after just starting the engine .....for the first 1/4 - 1/2 mile.......it makes a loud noise like the engine revving ....but the tach says it is not revving .....
Ive seen on other threads thats from an after market fan clutch......but at $220 - $290 for a mopar fan clutch who can blame me for trying a $40 one ?
How can you start out if the engine is off??
Old Apr 26, 2018 | 03:48 PM
durangolimited06
please read the entire thread , for some reason you two "moderators" dont see the entire post or get confused .....one more time I will try & explain .......when I first start the truck & move it ....it seems to rev high but not according to the tach ........it only makes this loud noise almost like another engine under the hood during the first 1/4-1/2 mile after a start up........it does not do it from then on until I shut the truck off again.......then I restart ( hot or not) & get the noise .....for the first 1/4 to 1/2 mile
Old Apr 26, 2018 | 03:50 PM
It's the clutch on the fan and it's perfectly normal.
Old Apr 26, 2018 | 03:51 PM
durangolimited06
how is this confusing ? ...please read all words......I said after the engine was shut off ..... & I fixed it to make it clearer ....if you still dont understand let me know
Old Apr 26, 2018 | 04:05 PM
durangolimited06
thank you ! thats what I am finding out , odd its only with after market fan clutches ......I dont want to spend the extra $150+ for a mopar part
