2nd Gen Durango 2004 - 2009
Racing idle
Old Feb 24, 2019 | 06:18 PM
05-Hemi-4x4's Avatar
05-Hemi-4x4
Default Racing idle
I just pulled my 2005 Durango 5.7 liter Hemi out of the garage and shut it off.
Now when I start it the idle goes to 4000 RPM.
No codes at all. Hooked the scanner up and nothing.
Any input would be greatly appreciated.
Thanks
Jim
Old Feb 28, 2019 | 11:36 AM
shelzmike's Avatar
shelzmike
Strange there are no codes; however, high idle are usually attributed to Throttle Position Sensor, PCV (either the valve or a vacuum leak), or Idle Air Control valve. Since you aren't getting a code, my fist guess would possible be the TPS failing. Sometimes, the codes are stored as grey initially and after x amount of times in x amount of time, it will finally trip the code. (Or go away if it doesn't happen again). Perhaps start it several times, if you haven't already, to see if a code pops up. There are a few other smaller things it could be like a dirty butterfly valve in the throttle body as well.
Old Mar 7, 2019 | 05:00 PM
Berserker1776's Avatar
Berserker1776
Thanks
Jim
Did you figure it out?
Old Mar 9, 2019 | 11:10 AM
05-Hemi-4x4
Never figured out why but the idle has been fine since. I ordered a new pedal /sensor just to be safe around $100.
