2nd Gen Durango 2004 - 2009
2004 Dodge Durango leaking
Old Dec 15, 2019 | 08:50 PM
Rachelroberson1989's Avatar
Rachelroberson1989
Default 2004 Dodge Durango leaking
I have 2004 Dodge Durango hemi 5.7. Today I noticed that behind the rear passenger tire that it was leaking. I’ve never had a problem. It was clean but oily. I’ve never had a problem before.
Old Dec 15, 2019 | 09:08 PM
primem's Avatar
primem
the component in the picture is the rear air conditioning thermal expansion valve. the ac system does have a small amount of pag oil but it doesn look like refrigerant/pag oil. the fluid on it looks like brake fluid or super clean rear diff fluid.
Old Dec 15, 2019 | 09:45 PM
Rachelroberson1989
How would I be able to tell if it’s the diff fuild. My brake fluid reservoir is full.ive never had this problem before as much as I have worked on my durango
Old Dec 16, 2019 | 08:37 AM
It's dripping down FROM those pipes, not spraying up onto them. Look at the splash patter below it. Think I would be taking a peak at whats above there, and see if it isn't something INSIDE the truck leaking out. Also, Could it be coolant?? I would imagine there is a heater core back in that area as well.
Old Dec 16, 2019 | 08:50 AM
Rachelroberson1989
Yea it’s dripping from the pipes. I do have a rear heater in my durango. But the heater has never worked since I got it. Just the a/c. The only thing above those pipes are for the heater/ac. I’m worried I don’t even want to drive it. I just put a new pcm in and are dying to get it back on the road
Old Dec 16, 2019 | 02:47 PM
primem's Avatar
primem
i think heyyou is correct. the tubes look to big to be ac...must be coolant.
