2nd Gen Durango 2004 - 2009
06 Durango 5.7 Hemi RE: Miss at idle
Old Sep 20, 2024 | 10:43 AM
dctaz37's Avatar
dctaz37
Default 06 Durango 5.7 Hemi RE: Miss at idle
My D has 170k km and when stopped at light there seems to be a miss causing the vehicle to shake. It is fine at highway speeds. I googled it and the search indicated may need to clean TBC and IAC. Not sure how exactly to do this or if this is where to start. I was originally going to change the plugs. Any ideas or instructions on cleaning if that is correct?
Old Sep 21, 2024 | 12:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is your check light on? Also check your vacuum lines. Could have a vacuum leak.
