2nd Gen Durango 2004 - 2009
Sticking front calipers
Old Nov 8, 2024 | 03:36 PM
Meatplow199's Avatar
Meatplow199
Default Sticking front calipers
New calipers new pads new brake master cylinder bleed and bleed these brakes but won’t stock sticking
Old Nov 8, 2024 | 04:32 PM
Have you replaced the soft lines? They break down internally over time, and become one-way valves....
Old Nov 8, 2024 | 04:35 PM
Meatplow199
no I haven’t but I got a good pedal and good pressure from the lines could what you said still be happening they visually don’t look bad
Old Nov 8, 2024 | 07:51 PM
Yep. Easy way to test. Jack up the front, pull a tire, pump up the brakes. If the caliper sticks, crack the bleeder open, I bet the caliper releases. Seen way too many of these.
