2nd Gen Durango 2004 - 2009
'04 Durango Hemi Engine Vibration
Old Apr 30, 2004 | 03:26 PM
mtroute's Avatar
mtroute
Default '04 Durango Hemi Engine Vibration
I have had my 04 Durango for over 800 miles. I have noticed that during light acceleration, ESPECIALLY, when cold, there is a slight vibration or resonance coming from the engine compartment. Any Ideas or information on this? I seem to remember reading something about this but breezed over it because it didn't concern me at the time.
Old May 1, 2004 | 02:05 PM
seanery's Avatar
seanery
Default RE: '04 Durango Hemi Engine Vibration
How 'cold' are you talking about? There is something in the manual that mentions the trans sounding, feeling slightly stiff/loud when cold and not to worry. I can't remember the exact wording or where in the manual it was, sorry.
Old May 3, 2004 | 05:01 PM
yawnshemi420's Avatar
yawnshemi420
Is it a sucking sound, when you barely hit the gas?
Old May 3, 2004 | 08:25 PM
mtroute's Avatar
mtroute
no, it sounds like a vibration but I don't feel anything. It is very dificult to describe...It really only happens at 1500 to 2000 RPM. And by cold I mean cold start, it has been in the upper 60's and 70 here in Portland so it's not like I am trying to start it during a Detroit winter.
Old Jun 15, 2004 | 10:12 PM
mtroute's Avatar
mtroute
Bump
3000 Miles and counting.
Old Jun 15, 2004 | 10:23 PM
seanery's Avatar
seanery
I really think it may be what I guessed at earlier. read the manual about the trans being cold. they mention the vibration specifically.
Old Jun 16, 2004 | 01:25 AM
chrisandclauida2's Avatar
chrisandclauida2
i have the same thing i think it is a resonense in the exauhst as things r warming up.it may be the transmission as it dosent matter how i warm the moter up i still hear it when i first drive so it may very well be the transmission. on a good note if it is something in the moter or transmission it will get worse fast as things like this that r signs of a moter or trans problem usually dont last very long till they blow and u will still be under warrenty
Old Jun 17, 2004 | 07:59 PM
chasmanz28's Avatar
chasmanz28
that resonance is the exhaust, sounds like its coming from the engine, if i remember dodge is supposed to fix this somehow i forget, think its something with the cats or some part of the exhaust to make it quiter, but i kinda like the sound
Old Jul 5, 2004 | 07:00 AM
04hemidango's Avatar
04hemidango
When I test drove my new Hemi, I immediately noticed the vibration at 1800 rpm. It is quite noticable. I drove 2 other Hemi's and found they were identical, so I figured it is a common thing with the Durango Hemi. I think it is an exhaust vibration, caused by resonance.
I plan to put a Masterflow muffler on, and eliminate the resonator in order to get a little more growl. I also hope this will eliminate the resonance. If this doesn't cure it, I'll try a K&N filter.
By the way, I now have 2,750 miles on my 'Dango after 5 weeks. I used it to tow my Cherokee on a flat bed down to Portland from here in Spokane the second week I owned it. Naturally, I took it easy on it, and let it putt on the hills. It never even noticed the 5,500 pound load behind it. Needless to say, I love the truck... even if it does have a vibration at 1,800 under light throttle load.
Old Jul 6, 2004 | 05:23 PM
Kodi's Avatar
Kodi
I have the same issue with my '04. I am told that the exhaust hangers need to be replaced. This is causing the vibration and harmonics I'm having at low speeds, especially when the engine is just warming up.
