2nd Gen Durango 2004 - 2009
electric brake
Old Feb 25, 2007 | 11:32 PM
pgtek's Avatar
pgtek
Default electric brake
Hi folks
I have a 2004 durango not sure if its equip with tow pak.
I know that on my trans lever there a button on the end for tow.
i'm planning to buy a trailer with electric brake.
What are my options on how to
any help is needed.
thanks
pgtek
Old Feb 26, 2007 | 12:13 PM
aka_chewy's Avatar
aka_chewy
Default RE: electric brake
Do you have the receiver hitch and wire plug-inson your durango? If you do, then I assume you have the tow package and would make getting set up a lot easier.
You will want an electronic brake controller to control the brakes on the trailer.These can be had for less than $100.00. You will have to run some wires to connect the controller to the wire plug-in.
I probably just created more questions than answers, but if you have any more, just fire away.
Old Feb 26, 2007 | 04:39 PM
pgtek's Avatar
pgtek
hi tanks for the replied
i install a hitch myself since it did not have one and they where asking an arm and a leg for one
i gueed there more work involve since i do not have a tow pack when i bought it
Old Feb 26, 2007 | 05:42 PM
aka_chewy's Avatar
aka_chewy
What you'll need to do then is run all the light wiring and the brake controller wiring. It shouldn't be to bad, most of it is plug and play. It will be just a matter of running the wires and where to mount the plug in for the trailer.
Good luck.
Old Feb 26, 2007 | 10:38 PM
jasonwyo's Avatar
jasonwyo
With the factory hitch and wiring they include at wiring harness that you have to sodder onto the after market brake controller. Then the wiring harness will plug into a light blue plug socket located under the dash up towards the emergency brake petal. If you can locate the factory wire harness adapter to connect to the aftermarket brake controller, its a 30 minutes job.
Old Feb 27, 2007 | 09:17 AM
pgtek's Avatar
pgtek
hi thanks for the info
I've check under the dash near the e brake and cant see that blue connector.
Old Feb 27, 2007 | 09:19 AM
pgtek's Avatar
pgtek
ho
it's not a factory hitch i bought and i bought universal 7 pin wire harness
Old Mar 16, 2009 | 12:06 PM
aerostern's Avatar
aerostern
I have a 2004 durango with tow package, have the blue plug. Trying to get the electric brakes on my boat trailer working. I ordered a Tekonsha Prodigy Proportional Brake Controller with Dodge adapter.
http://www.etrailer.com/tv-brake-con...e-durango.aspx
Is the only thing I need to do is plug this unit into the blue plug? Do I have to do any additional wiring to get the trailer brakes to work?
Thanks...
