2nd Gen Intrepid 1998 through 2004 Intrepids
A day at the dealer
Old Aug 25, 2007 | 11:03 PM
trep02n's Avatar
trep02n
Default A day at the dealer
so I took my car to the dealer you know about the problem with code p1776 before I took it I changed the trans fluid and also put a new filter in.It is trep 02 with a 2.7 engine so
the car stayed there for a day and this is what they told me
1- I needed trans fluid to be changed and a new filter
2- Also needed a trans flush
3-the total $470 to do it
4- would that fix my problem they said maybe
5- They also told me I may need a new trans
So I ask to talk to the mechanic that checked my car but he was in his lunch break
guys I realy need help on this can someone help me out on how to fix this problem
Old Aug 27, 2007 | 12:21 AM
kurts2's Avatar
kurts2
Default RE: A day at the dealer
Try a transmission shop and see if they can fix your solinoid problem without an entire transmission change.
Old Aug 27, 2007 | 08:30 PM
trep02n's Avatar
trep02n
thanks man
Old Aug 31, 2007 | 10:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
I don't know what dealer you went to, But P1776 is for valve that has gotten stuck or latch position. In other words they should have told you that you needed a valve body and that comes with a new filter too. Maybe the techs the dealer have is not trained on transmissions. Do you know if your car still have powertrain warranty? When ever you go to a dealer ask for a level 4 tech, not a lube tech.
