2nd Gen Intrepid 1998 through 2004 Intrepids
Wipers gone crazy
Old Sep 9, 2010 | 05:40 PM
buckz6319's Avatar
buckz6319
Default Wipers gone crazy
Dodge Intrepid 2001 SE 2.7 120,000
the title says it all
I was told by a mechanic to replace the wiper motor/module assembly, and that should fix the intermittent stopping
does anyone have a pic of this assembly for me to look at?
I'm not totally convinced this will cure the problem but maybe it will
thanks for any input
Old Sep 10, 2010 | 10:21 AM
torsiondrummer's Avatar
torsiondrummer
http://manuals.dodgeintrepidchat.net...97-01/01LH.pdf
If it's no problem getting to it, look on pages 293, 294 & 295. That should be for your vehicle, 2001~
Old Sep 10, 2010 | 07:16 PM
buckz6319's Avatar
buckz6319
thank you for your time
I looked at the link and saw the assembly,now I think I just need to replace the wiper motor with module.I will check into this over the weekend
Old Sep 10, 2010 | 08:40 PM
buckz6319's Avatar
buckz6319
I just went out to look under the hood of my car with a flash light because it's dark out side(you know that sometimes you can see more under the hood at night with a light for some reason)
I saw something that looked like a wet oil spot on the rubber PCV hose.I put my finger on it and the spot was wet with a hole in the hose, the hose was vary vary soft and just collapsed....so just maybe this is the culprit that is causing my code P0455?
going to replace the PCV and hose tomorrow
