2nd Gen Intrepid 1998 through 2004 Intrepids
2000 intriepid 2.7l vin u swap with 2002 vin r
Old Nov 25, 2011 | 01:14 PM
Fredonia's Avatar
Fredonia
Cool 2000 intriepid 2.7l vin u swap with 2002 vin r
Swapped a dodge intrepid 2000 2.7l vin u with a 2002 2.7l vin r ... Will turn over but won't fire ... Dino says no compression on 3 cylinders ... How do i modify engine to fire
Old Nov 25, 2011 | 09:06 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
What do you mean by "dino says no compression on 3 cylinders" ?
What flexplate did you use in the car, the one from the donor, or the one that was already in the car?
Old Nov 25, 2011 | 11:04 PM
Fredonia's Avatar
Fredonia
Cool Swap 2000 2.7l vin u with 2002 vin r .. No start
Used 2000 intrepid trans & flex plate with 2002 eng 2.7l vin r
Old Nov 25, 2011 | 11:05 PM
Fredonia's Avatar
Fredonia
Diagnostic machine test
Old Nov 26, 2011 | 01:15 AM
TNtech's Avatar
TNtech
Ok, Im am assuming the car is a 2000, correct? The only way to know compression is with a gauge. If you truly have NO compression on a whole bank then that would be catastrophic. Not very likely.
On the Intrepid in 2002 the PCMs went to NGC type (New Generation Controller) The 2000 model did not have this type yet. Your flexplate is going to be fine, however you are going to have to use the driver's side cam gear from the 2000 engine for the cam and crank sensors to be able to sync together with the PCM. The slots in the cam gear pickup and flexplate pickup are arranged different between old style and NGC. At least you don't have to pull the engine out...that's good.
