audio question
Old Apr 17, 2007 | 04:59 PM
contagious19's Avatar
contagious19
Default RE: audio question
well i dont have tweeters in my dash and i was lookin at some at cardomain store and they have 3 1/2" and i wanted to check before i buy them. and my audio is good i have good bass and everything but i want my audio to sound a lil bit clearer so ima get some tweeters and it should be good.
Old Apr 17, 2007 | 08:59 PM
Pablodragon's Avatar
Pablodragon
This comes up again...maybe someone can confirm.....can never seem to get a postive or negative answer...
If you have the small stock speakers up in the front window... are these really tweeters or just small full range speakers?
I have a 2004 SE and it came with a cassette deck, just find it hard to believe that they would give me tweeters on the low end model and hooked to a cassestte deck....?
Old Apr 17, 2007 | 09:33 PM
867neon's Avatar
867neon
thanks for all the info. the cd player i got is Pioneer DEH-P3900MPas for the type of sound i want, i just want something that sounds clean, if that makes any sense. but i think i'm gonna try getting the amp (4channel)and then i'll see about the sub(since i'll be needing a separate amp,right?) also how many watts would you reccomend the amp to be? (the speakers(4) are 230w)
thanks in advance
Old Apr 18, 2007 | 02:11 PM
RestrictXXX's Avatar
RestrictXXX
Junior Member
There small full range speakers. There aren't any crossovers or factory amps in the basic neons.
Old Apr 18, 2007 | 03:25 PM
Pablodragon
ORIGINAL: RestrictXXX
Thank you...finally...so we can all stop calling these tweeters UNLESS you have upgrade factory stereo or you have personelly replaced them[:@]
Old Apr 18, 2007 | 05:36 PM
contagious19
do u know how many rms watts? is dat 230 watts for all or a pair?
