underdrive pully
Old May 13, 2007 | 08:01 PM
Kalevra's Avatar
Kalevra
Default RE: underdrive pully
heat makes metal expand... heat up the engine and put the UDP in the freezer
Old May 13, 2007 | 08:04 PM
03neonRT's Avatar
03neonRT
I would highly suggest againt working on your engine while it is still hot...to take the pulley off, just get a 3-jay from Autozone, find an appropriate insert (dont use the crank bolt or you'll risk stripping the threads). Once the stock pulley is off, put the new pulley in an oven at 450 degrees for 30 minutes. Take the new pulley out of the oven, and slide it right onto the crank. Its as easy as that...
Old May 13, 2007 | 09:37 PM
Izero's Avatar
Izero
what do you mean find an insert??
Old May 14, 2007 | 01:44 PM
nswap7's Avatar
nswap7
it looks real similar to the UR.. How are any better than others? they all look similar and go in the same spot and for the most part are same size. i dont know i just was curious
Old May 14, 2007 | 06:41 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Izero
The pulley puller pushes "inward" on the insert while pulling "outward" on the pulley itself. Some people use the stock crank pulley bolt but I would be worried about stripping the threads on the bolt or the inside of the crank...one option is getting an extra crank bolt, then grinding off the bolt head and threads to use as an insert...I've actually used a long socket extension though [8D]but I really wouldnt suggest that either. Did I explain that ok?
Old May 14, 2007 | 08:43 PM
Izero's Avatar
Izero
kinda..... idk i've never really looked at it, on my car so im having trouble picturing what your talking about... but for the most part it seems like its a bigger pain in the neck to do it myself than to have someone else do it.....
Old May 14, 2007 | 10:08 PM
jobar26's Avatar
jobar26
I buy a udp from that seller,i pay the pulley 8 april and i m still waiting the damn pulley!!!!
Old May 15, 2007 | 02:22 AM
Kalevra's Avatar
Kalevra
I guess i'm not getting it XD
