srt swap
Old May 13, 2007 | 10:24 PM
2kneon's Avatar
2kneon
Default srt swap
Ive got a 2000 dodge neon es and my engine is on its last leg. i waant to engine swap with an srt-4. is is straight bolt up or not? if not what will i have to do to make it work. i have never done an engine swap before please help.
Old May 14, 2007 | 02:49 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: srt swap
it will fit in directly i think, buttttt the wiring is COMPLETELY different, so you would have to rewire your whole car
Old May 14, 2007 | 02:56 AM
LowSlowNeon's Avatar
LowSlowNeon
Yes it will fit. Engine, tranny, wiring harness, pcm, and axles are the big things I can think of at the moment.
Old May 14, 2007 | 03:17 AM
Kapitald's Avatar
Kapitald
Thanks to -03neonRT-
For the SRT-4 turbo engine, you will need the following parts:
Engine and Tranny
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Lower Motor Mounts (the hole in the lower mount is larger for larger bolts)
SRT PCM (wont' need the bracket if swapping into an 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line from tank to engine bay
Fuel Pump
Flex Fuel line from solid fuel line to fuel rail
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + o2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Some options parts would include:
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
The stimated cost will be anywhere from $3,000-$5,000 depending on many factors...if you install it or not, are you buying a donor car, or just the engine/tranny, and costs for misc. parts, etc...
Old May 14, 2007 | 03:20 AM
LowSlowNeon
Lol, well it depends how cheap you want to get by. But that is a more thorough list.
Old May 14, 2007 | 03:25 AM
Kapitald's Avatar
Kapitald
yes....lol...i go and find it for these guys ..bc all these newbs ask for the srt swap as soon as they become a member
Old May 14, 2007 | 04:54 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
yes, i have noticed this subject of thread quite frequently.
Old May 14, 2007 | 11:52 AM
xenoneon's Avatar
xenoneon
yeah this topic is very popular, i am gettin my swap done soon yeahhh. lOL good luck with urs
