Project Begins
Old May 16, 2007 | 05:29 PM
Dolla316's Avatar
Dolla316
Default Project Begins
So i found out that i was screwd over onmy car repair...I bought a new motor for my 02 ES that i really didnt need...The guy jus sprayed this copper stuff on tha head gasket to make it work but it didnt...So now i have my old motor out and have decided to jus make it a project motor...I need a lil help tho...I need some suggestions on some parts...Like wat type of pistons should i get, oil pump, and so on...Basically im jus wantin to rebuild tha whole thing...So if i could get some help that would b great...
Old May 16, 2007 | 05:35 PM
NHARINTON's Avatar
NHARINTON
Default RE: Project Begins
Modern Perfomance has everything you will need to do a full performance overhaul. I have my spare motor sitting in my garage....... not i just have to get the money to do it.
Old May 16, 2007 | 05:42 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Dolla316
What are your plans for the motor long term...N/A or F/I?
lblackneon's Avatar
lblackneon
Howell has the stroker kit for the Neons. I'd stroke it. Be sure to compare prices between Howell and Modern Performance.
Old May 16, 2007 | 05:45 PM
Dolla316's Avatar
Dolla316
Well the plan is jus to make it fast but still everyday driver til i get my 09 SS Camaro...
Old May 16, 2007 | 07:24 PM
Izero's Avatar
Izero
well first off if i were you i would wait a year before getting the camaro.... since its the first year they are bringing them out you might want to wait a year as you never know what kinda of problems they might have with the car once it hits a mass production rate.... now as for your motor.....:
get yourself the r/t head(and w/e else you need to make that work)
get the comp 400 cam( or a #10 cam),
the unorthodox Underdrive pulley
adjustable cam gear
get the cylinders bored .20 over
the AFX aftermarket PCM
the 8.5 compression bottom end kit w/ the .20 over pistons from modernperformance.com
the matching top end kit
to finish the motor off i'd buy a hahn stage 2 turbo kit (you can ask for the 20g turbo instead of the 16g if you want too)
then dress the motor up with an MSD ignition,
powdercoated valve cover w/ a billet oil cap
prothane motormount inserts
im not sure if you are going to need the following as idk if some of it comes with the stuff in the Hahn kit or not but here goes:
might need larger injectors (SRT stage 0 would prolly be fine)
a fuel return kit
walbro 255 fuel pump
Fuel pressure regulator
and then there is the optional stuff:
oil overflow can
coolant over flow
larger oil pan (howellautomotive.com)
im prolly missing a bunch of stuff here and there but all of that will prolly get you to like 250-300HP maybe more.... but either way thats basically how i am going to build up my motor i think but i haven't made up my mind yet...
Old May 16, 2007 | 07:25 PM
Adionik's Avatar
Adionik
Why would you get an R/T head if you're eventually going to get the hanh
You're going to switch manifolds anyway right? Why waste the money.
Old May 16, 2007 | 07:55 PM
lblackneon's Avatar
lblackneon
The RTs head (magnum head) has larger exhaust ports. You'd spend more money if u plan on turboing the car and ended up getting a header to go with the rt head. If u get a turbo, you'll get a downpipe to go with the turbo kit.
If you're going very deep into the engine and plan on porting and polishing it, you wont necessarily need to get the RTs head. U could just port the exhaust ports on your cylinder head by itself. It's your choice.
