MM install
Old Jun 14, 2007 | 06:31 PM
  #21
Freerider's Avatar
Freerider
Default RE: MM install
ORIGINAL: nswap7
i just noticed on the instructions, it said torque to factory specs..did any of you do that easily? what is the factory specs?
Just torque them down with 2 "oh *****"
Old Jun 14, 2007 | 07:22 PM
  #22
nswap7's Avatar
nswap7
lol..k
Old Jun 15, 2007 | 03:10 AM
  #23
nswap7's Avatar
nswap7
yah, so i started it today, but had to cutt myself short cuz i had to go to work. i was trying to put the top in,but the right side of the factory bushing wouldnt let the insert go in, and the washer fluid bottle is right there so i cant hammer towards the bottom of the insert. i ended up putting the the mount back on without the inserts in today. gunna try it again tmrw. did anyone do it w/o taking the old insert out? what should i cut it with if i have to. the razor blade was a pain
Old Jun 15, 2007 | 03:35 AM
  #24
neon03se's Avatar
neon03se
i believe kapitald did it without cutting anything
Old Jun 15, 2007 | 03:53 AM
  #25
nswap7's Avatar
nswap7
yah.i just saw that. i wanna get this done early in the morning so i hope someone will input..lol
Old Jun 15, 2007 | 07:40 AM
  #26
Freerider's Avatar
Freerider
you SHOULDNT take the old inster out. The old insert is what the new insert grips into!!! Take a knife, like a pocket knife, and cut away at some of the excess rubber meterial until the insert slides in. Its no problem! Just take your time and be careful. Little bits at a time. I think I took out quite a bit but just work slowly till it just slides in.
Ill take a good picture for you tomorrow.
Old Jun 16, 2007 | 05:56 AM
  #27
nswap7's Avatar
nswap7
ok, i got them in. it was a hell of a time, but i did it.they are a great mod for so cheap. The vibration is tolerable, and for an automatic, i felt like they gave me easier shifts(not throwing me out thru the trunk). The only thing that bugs me is how the lower mount's bolt sticks out a littl, but i didnt see if it is suppose to be like that. i also have to go back and remove the stock washers cuz i kept them on. The other thing is that i can hear it vibrate sometimes more than i feel it at times. im guessin there should be a rattle.my buddy did most of the work cuz i had to do the brakes and hub on our other project. thanks guys
