Gauge cluster interchangeability
Old Jun 12, 2007 | 04:17 AM
nswap7's Avatar
nswap7
Default RE: Gauge cluster interchangeability
swapping is as simple as taking off the pillars, then the dash board, then unscrewing the cluster and undoning the wires. that is if you're doing tach to tach or non to non
Old Jun 12, 2007 | 04:20 AM
neon03se's Avatar
neon03se
what bout non to tach?
Old Jun 12, 2007 | 04:24 AM
nswap7's Avatar
nswap7
im not completely sure to be honest. all i know is that your gunna do some wiring in the bay. I use to have a faze external tach w/ shift light on my crx, but dont even remember how i wired that up
Old Jun 12, 2007 | 05:03 AM
Pharmboy's Avatar
Pharmboy
the tach should work with just a swap all the wiring is in place but that may be different between years so that's what I was wondering about. I'm betting the harness is the same though.
Old Jun 12, 2007 | 05:13 AM
03neonRT's Avatar
03neonRT
All 00-05 Neons are wired for a tachometer, regardless of whether your cluster came from the factory with one or not. So, all you have to do is find a cluster with a tach, take out your old one, plug the new one in, and your done.
Old Jun 12, 2007 | 04:06 PM
neon03se's Avatar
neon03se
thanks RT, now the hard part is to find a cluster close to my mileage and in good looking condition, the search begins!!
Old Jun 12, 2007 | 04:42 PM
Pharmboy's Avatar
Pharmboy
sweet
Old Jun 21, 2007 | 01:44 AM
neon03se's Avatar
neon03se
i have been readin some auctions on ebay for the white faced cluster, and have read that "most chrysler vehicles store the actual mileage in the ECU. Is this true, supposedly all you have to do is plug in the cluster and it should show your actual mileage because it supposedly "stores mileage in the ecu". anyone here actually swapped out clusters and this happen for them??
Old Jun 21, 2007 | 02:36 AM
neon03se's Avatar
neon03se
bump
Old Jun 21, 2007 | 05:47 AM
03neonRT's Avatar
03neonRT
ORIGINAL: neon03se
The mileage is stored in both locations, but if you plug in a different cluster your mileage will not appear on the cluster...the system just wasnt designed to erase the cluster memory and replace it with the ECU mileage reading. A GM will do it that way, but not on older Chrysler vehicles...
